New member Username: Cam309Gulfport, Ms USA Post Number: 1 Registered: Jun-05 | I just recently bought a 1995 Mazda 626 and i would like to put my own CD player in. The problem is, i don't know how to take out the tape player. Can anyone help me??? Please!!!! |
Bronze Member Username: DvautierBellevue, Wa Usa Post Number: 18 Registered: Feb-05 | you should be able to remove the bazel by prying a little bit. be sure to remove the screws under the dash. after the bazel is off the rest is easy. Also determine the kind of radio you want to put in. What is the size? Is it din, din and ½, or double din. With a mazda my guess is it is din, which is a pretty standard size so you can get just about any OEM player/radio around. Then get an automotive wiring book to help you with the wiring. I have a few web pages that describe my various exploits: http://dvautier.home.comcast.net/radio/radio.htm but there is just a ton of stuff out there on this very topic |
Mary Souter Unregistered guest | On my 95 protege's tape player, it comes on and off spontaneously and sometimes i have to turn the ignition off then back on for it to work. Is there any simple way to fix this? |
