Ok here's my dilemma: I plan to buy the NAD 352 Integrated AMP and for speakers here's what I am thinking: 1. MA S6/S8 2. JM lab 714 S 3. Energy C7 4. Paradigm Monitor 7 / Studio 20
I know this is a lot of choice but given that I can get these within +- $150 which one should I consider?
I would nix the Paradigm Monitor 7 in that competition. Listen to them all if you can but with special interest to the MA, JM Lab, and Paradigm Studio 20. Again that is just my opinion. Best judge is YOUR ears.
I agree with Art - nix the Monitor 7's (I had them for 3 years)..the Studio's are way above them. Also, make sure you listen to them (side by side if possible) as the MA Silver series will definately have a different sound than the Pardigm's (to me, if you are into Rock, or like to listen at higher volume levels, the MA is the way to go between those). Good luck! Shaun
ZiggyZoggyOiOiOi
Also Neeraj... with the Energy speakers you may want to check out the C-5s. Even though they're less money than the C-7s, I found them to have a richer sound with much better midrange than the C-7s. But you can't really go wrong with any of the speakers you're considering.
The B&W 600 series is comparable. IMO the Paradigm Studio 20 will sound better than any of them although the MA may be close. Sounds like it's time for an audition.
