New member Username: Mrun123Post Number: 3 Registered: Jun-05 | I have Speakercraft AIM8 One's and an SVS Sub in my family room, a pair of Klipsch in-ceiling speakers in my dining room, and a pair of Klipsch outdoor speakers on my patio. I am buying a new receiver, either a Denon 2805 or a 3805. What is the best way to connect these three "sets" of speakers to my receiver? I don't understand how a speaker selector operates, but it seems like that might be an option. Does it connect to the amp output on the receiver and the two remote pairs of speakers connect to the selector? Before I purchase the receiver, I would like to understand how things are set up so I can make my receiver choice wisely. Also, any comments on receiver options would be greatly appreciated. Thanks in advance for the advice and expertise. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 4056 Registered: May-04 | http://www.xantech.com/ http://www.inwallstore.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=i&Categ ory_Code=_info http://www.hometech.com/audio/ http://www.prillaman.net/ht_info_8-wiring.html Read a bit and see what you find. If you have questions, call the company to ask specifically about that company's products. |
New member Username: Mrun123Post Number: 5 Registered: Jun-05 | Thanks, Jan. I decided to go with the Denon 2805 which should be relatively straightforward to set up. I'll definitely check out those sites. |
