Sony strde595
I have a Sony STR-DE595 surround sounds system that was recently hooked up to my homes existing speakers. I was listening to digital audio fed from the cable box and suddenly a loud blip came through the speakers and the panel on the receiver went dark. Now, it will not turn on. Is it fried for good? What would cause this?
Username: Jet2001
Post Number: 51
Either fried or a blown fuse...if you wish to keep and fix it, take it to your nearest Sony repair shop. Good Luck!
