Downfiring or frontal
Username: Dodgedifferent2
Post Number: 15
which type of subwoofer do you prefer? or think is better?
Username: Artk
Albany, Oregon USA
Post Number: 683
Downfiring, seems less directional.
Username: Joe_c
Oakwood, Ga
Post Number: 357
ditto
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 719
I've never heard a front firing one in my home, only 3 different down-firing ones. Directionality shouldn't matter is croosed over low enough, right? say 80 Hz?
Username: Jan_b_vigne
Dallas, TX
Post Number: 4003
Yes, bass becomes increasingly omnidirectional as the frequency descends. Localization of a bass signal is taken from the rising harmonics of the signal which are produced predominantly by the satelites. At the frequencies a typical subwoofer operates in a home audio or home theater system, there shouldn't be significant output at any frequency that lends directionality to the subwoofer. If that were actually the situation, you would need two subwoofers to maintain left/right balance; would you not?
In my opinion the front firing sub will allow more placement options. A downfiring sub will be dependent, to some extent, on the distance from the driver to the floor for its reinforcement effects. Since most people have their subwoofer placed on the floor, this is most often not a problem. The subwoofer designer can count on that distance and the amount of boost it provides when designing the system. But I have found the smoothest response to be off the floor on a short, rigid stand. It eliminates one boundary effect which tends to add lumpiness and thickness to the bass. Of course, if that lumpiness and thickness are the sound you desire ...
Post Number: 732
Interesting. I might try that sometime. Thanks for the tip!
Hey, you broke 4000 posts!
Dallas, TX
Post Number: 4007
Shhhhhhhh ... some people don't like to hear that.
Post Number: 733
Just 60 more posts and you take the number 3 spot.
Then number 2 is close...
But you'll need to double to reach number 1!
Username: Joe_c
Oakwood, Ga
Post Number: 375
Glasswolf is overrated anyway. One of jans posts makes up about 10 of his.
Samuellel
I have been giving this a lot of consideration and I can't make up my mind. What are your thoughts?
Which one has a better deal Dishnetwork or Directtv?
