Help With Paridigm Speaker Selection
dtc17
I am a fan of Paradgims and now want to put a new Home theate system in my basemetn.
Fronts - Monitor 3
Center - CC370
Rear - This is the problem.
Space limiations means very samll or in-Ceiling is the way to go. What do I choose? Are the Paradigm SM-60Rs a good match. I heard not. What aobut Cinema ADP?
Username: Bacchanal
Paradigm Atoms might work. They're small and would be sufficient for surround channels with the Monitor 3s up front
Username: Elitefan1
Post Number: 273
I also would recommend the Atoms. Excellent speaker for the size and price and would work well as a surround. Are you locked in to the 3's for your fronts? I think the monitor 5 is a better buy for the money.
Username: Northexposure
thereallitefan - I'm also looking for fronts for a surround and am considering Paradigm. For my size of room (22 x13 x8), I thought the monitor 7's would work well. How would you compare them to the 5's? Have you compared them to comparable PSB speakers? And have you hear Axiom speakers?
