I'm trying to decide on a receiver and looking for advice.
I've always liked Harmon Kardon so I'm looking at the DPR 1005 and the AVR 630, both are $400 to $500 on ebay. The DPR's digital processing sounds cool, but there is something to be said for older robust technology like the AVR.
I'm in the middle of upgrading my audio equipment. The speakers the receiver will be running are JBL E90 front speakers, JBL EC35 center, and older JBL bookshelf speakers in the rear. I plan on adding a powered sub, and extra surround speakers later.
The receiver will be used for home theater 60% of the time the balance a wide range of music.
Go to avsforum.com and do a search for "list of digital receivers"---it's a huge +40 page thread.
You'll find that the DPR1005 gets some pretty bad reviews. The DPR2005 however gets plenty of raves...goes for around $750 new so Harman Direct on eBay should have it for $500-600.
I think B&H Photo has the best deals on JBL speakers, check them out if you haven't bought already.
However the JBLs are known to be a bit bright so they'd probably sound better with an analog receiver, just my guess.
