Anonymous | I just want to use them when everybody is sleeping to listen to tv or movies or music. Thanks |
Silver Member Username: EramseySouth carolina United States Post Number: 160 Registered: Feb-05 | Sennheiser brand, very good. E.Ramsey |
Silver Member Username: DiabloFylde Coast, England Post Number: 117 Registered: Dec-04 | I've had a set of Sennheiser HD570s for a few years. They sound pretty good, though not as much bass as some. A good point about them is the very tough single cable. I used to get through a pair of 'phones every 18 months at one time - due to the cable becoming faulty. Wireless 'phones are not much good usually, unless they have improved a lot recently. |
guest Unregistered guest | I like my Grado SR80's but they definitely cannot compete with the high-end Sennheisers. Good headphones for someone on a budget though... |
Silver Member Username: EdisonGlendale, CA US Post Number: 623 Registered: Dec-03 | Look here for pro's take on it : http://www.hifichoice.co.uk/buyersguide_list.asp?category=HPH&subcategory=HDPHN I personally like AKG headphones. Also technics make good ones - 800 model. |
Bronze Member Username: AlexfromhollandPost Number: 36 Registered: Aug-04 | Hi, I own the Philips HD890. The sound very good, very detailed sound. And they are cheap: EUR 59,-. Alex |
Silver Member Username: DmwileyPost Number: 761 Registered: Feb-05 | Sennheiser and Grado. All the rest are poor imitations and wannabes. Just an opinion. |
Silver Member Username: TdbdrummerPost Number: 474 Registered: Feb-05 | Clearly the 70's Koss PRO-4AA's are GREAT! The newer aren't bad, but have higher treble response. |
