How do i hook up a car amp to a home stereo
i have a 250 watt 2 channel car amp and 2 subs. how the heck do i hook the car amp to my home stereo
Username: Virus5877
West Lafayette, Indiana USA
Post Number: 116
you need to find an AC to DC converter that will convert 120V AC to 12V DC with max output of at least 20 amps. That's the only safe way to do it.
The Jerry-rigged way to do it is to run the amp off of a car battery that is attached to a car battery charger.
how do i hook up a 750 watt sony xplod car amp and 2 mtx 12" subs to a 100watt panosonic home stereo
Username: Audiobahnguy
if your talking about inputting 750 watts into your 100watt stereo time to see some smoke!my advice if you got a goodwill usually they sell some great stereos for low low prices buy one...
joey cerqua
how do i hook up all the wires from my home sterio to my amp and then to my mr3 subs
