New member Username: Sman789Post Number: 1 Registered: Jun-05 | I have an Iriver h120 (has a line-out and a headphone out ![]() i was wondering where i could find a simple amp 2ch and enough to power just these speakers so i can listen to music at work. Or is it even worth it, the speakers work well and i checked them for continuity and theyre good. but the amp i hooked them up to aren't powering them enough (i used a dvd/reciever home theatre package amp) |
Silver Member Username: Virus5877West Lafayette, Indiana USA Post Number: 117 Registered: Apr-05 | Try the NAD C320BEE, it's a pretty basic integrated amp that should power the bose quite nicely. (and don't worry about the power ratings, NAD underrates BIG TIME!) |
New member Username: Sman789Post Number: 2 Registered: Jun-05 | wow thats looks good....does anyone one know of some budget options |
WEC Unregistered guest | This is pretty budget. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=39791%26item%3D5780324082 %26 |
Silver Member Username: EdisonGlendale, CA US Post Number: 631 Registered: Dec-03 | Onkyo RX-LR552 is a good one for $200 on the web. |
Silver Member Username: EdisonGlendale, CA US Post Number: 632 Registered: Dec-03 | You might want to consider this speaker - has an amp built in, and sounds better than the Bose. http://www.newegg.com/Product/Product.asp?Item=36-136-102&depa=0 |
