I have two amps working as monoblocks and have speakers that support bi-wiring....anyway, I am running a set of cables from the amp's "A" speakers to one set of posts and another one from the "B" to the other set of posts so.....am I bi-wiring or bi-amping?
Thanks a lot and please do not be too harsh on me !
You're not stupid, I am. Just check the name! Anyway, if the speaker wires are coming from the same amp - using speaker outputs A & B from the same amp to each speaker, you are bi-wiring. In your instance, you would need four mono-blocks to bi-amp two speakers. For example - Amp 1's output goes to one set of the right speaker's binding posts, and amp 2 goes to the second set of the right speaker's binding posts. Amps 3 and 4 would work the same way on the left channel. hope I didn't confuse you.
Chichio
Man,
You are a good soul, thank you so much for the lesson.
