Pre Out to 5 channel In
wct111
Is it possible to hook up 2 receivers using the pre out from receiver number 1 To 5 channel input
to receiver number 2.
Username: Jan_b_vigne
Dallas, TX
Post Number: 3934
NO! Pre amp outputs are meant to run into power amp inputs, not another pre amp input such as 5.1 in. What are you trying to accomplish?
wct11
I've got a new receiver that doesn't have have a phono input as well as a lot of OPT inputs. I'm just trying to link the 2 receivers and use them
with one set of speakers. I probably could use the tape in and outs hooked up to out put the turntable. This would work for analog signals. What about digital signals like CD recorder. digital
