Silver Member Username: ArtkAlbany, Oregon USA Post Number: 605 Registered: Feb-05 | Little outlay, big return. You want to improve your sound for very little dough, pick up a set of pods and use them on your cd player. I am using them on all of my gear. Makes a big differnce. Lowers noise, increases dynamics, enhances and deepens soundstage. Presentation is more 3 dimensional and life-like. Cost $5-6 per pod or $20-24 per component. Great perfromance enhancing drug for your system. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 3910 Registered: May-04 | The units with the captured ball bearing is a substantial upgrade. They are to be used either alone or with the original Vibrapods. http://www.audioadvisor.com/store/productdetail.asp?sku=VIBRACONE |
Silver Member Username: Edster922Abubala, Ababala The Occupation Post Number: 687 Registered: Mar-05 | art, I can see this making a difference with any components that have many continuously moving parts like turntables, cd/dvd players, tape decks...but how would it improve SQ on a more inert component like an amp/receiver? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 3915 Registered: May-04 | Do power transformers not vibrate, eddie? Do you believe only components which move are susceptible to outside feedback? |
Silver Member Username: ArtkAlbany, Oregon USA Post Number: 608 Registered: Feb-05 | Precisely. |
Gold Member Username: Rick_bNew York USA Post Number: 1156 Registered: Dec-03 | May I also suggest Mapleshade brass isolation cones. I use them under all my components. Highly recommended. www.mapleshaderecords.com |
Silver Member Username: Edster922Abubala, Ababala The Occupation Post Number: 698 Registered: Mar-05 | jan, LOL i really don't believe you can be that obtuse, but since i would feel really terrible to leave so many wrinkles on your forehead: Art, do you hear as much of an improvement using these pods on components with vibrating parts (receivers, amps) as opposed to components with SPINNING parts (e.g. a CD player)? |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 3925 Registered: May-04 | Obtuse is as obtuse does, eddie! |
Silver Member Username: Edster922Abubala, Ababala The Occupation Post Number: 700 Registered: Mar-05 | yes indeedy... |
Silver Member Username: ArtkAlbany, Oregon USA Post Number: 609 Registered: Feb-05 | Every component that I use them for results in improvement. Very small investment for big returns Edster. |
