Replacement Rack system parts
Username: Snyiper
Southern
I have a old Technics rack stereo system and the intagrated amp just up and quit (said it was overloaded anyway). Well the rest of the system seems to work, what could I use to replace this? I know this is a dated system so Ill replace everything as it goes or I can afford it. Right now this is the only dead piece. I like my stereo but am not what you would call a diehard, something compatible to the SU-G75 or a bit better would be fine new or used...any ideas I am totally new at this?
Glenn
Username: Jan_b_vigne
Dallas, TX
Post Number: 3863
More often than not when the major portion of a rack system dies, the only option is to replace the entire system. Take the unit to a Panasonic repair center and get an estimate on repairs is the only suggestion I can give.
