New member Username: HidethebeansBerlin, Berlin Germany Post Number: 1 Registered: May-05 | hi, recently i found an mp3 on the ground so i took it home and was loading songs onto it, but while i was doing that, the message "incorrect format, reformat the player" shows up, and the songs wont play and i cant load any other ones up. as i found it on the street, i dont have an instruction book so i dont know what to do. its a usb stick if that helps, and im not sure about the company name, but it says "PRO2 WMA MP3 digital music player" on it. any advice is welcome. |
Anonymous | every time i go to turn my mp3 player on it tells me incorrect format reformat player... what do i do |
titch Unregistered guest | ye im havin that same problem wot mp3 player do you have?? i have a napa one |
Unregistered guest | hello i have the same problem my mp3 player is alba and 256KB it worked for a copule of months and suddenly on the LCD screen it read "incorrect format reformat player" can u please helpp me overcome this situation??? THANKZ! |
Unregistered guest | Hi, I`ve got the same problem with my MP3 stick. If someone knows how to reformat it, please tell me! thx |
New member Username: WumingsdenNottingham, East midlands England Post Number: 4 Registered: Aug-05 | To all: Plug in MP3. On my computer click on corresponding drive, I use F. Click on properties, then hardware, the properties, then uninstall or roll back driver. I recommend uninstall. Then plug in your usb again and done |
New member Username: LobbersPost Number: 2 Registered: Aug-05 | to wu, i clicked on my computer but i carnt find corresponding drive! could you tell me where it is please x |
Unregistered guest | so has ne1 found owt how 2 reformat an mp3 player |
dragoszaman Unregistered guest | I have one too (pro2 wma mp3 DIGITAL MUSIC PLAYER)but mine working like memory stick and does not appear anything on the screen when i press on/off button. Does know anyone the manufacturer ? It appear to be a SigmaTel MSCN USB Device. |
Anonymous | manufacturer not found in world. my player's problem another lcd display corrupt. anyone to sell your player to me thanks. my mail adress mithataltin@yahoo.com |
New member Username: MilobeanCourtenay, B.c Canada Post Number: 1 Registered: Nov-05 | hi i just got a perfectmicro 2.512mb mp3 player and when i went to install the software i some how erased all the data off the mp3 player so now when i turn it on the screen lights up then it just shuts off and there is nothing in the display if some one could help that would be great. thanks |
