Recommended power alternator per RMS
IangY
according this site (http://www.the12volt.com/info/recwirsz.asp) i should have a 120 alternator at least in order to handle a 800 RMS audio system.
I'm thinking about buying a 800 RMS kenwood amp to power my 2 12" subs. My alternator only works at 70 amps.
Should be enought to handle it ? What about buyin' a 1 farad capacitor, should it help without upgrading the alternator/battery. I just want to know if my alternator will work for 800-900 RMS.
Regards
you really upgrade your alternator cause it will power you system and and keep your battery charged
you really upgrade your alternator cause it will power your system and and keep your battery charged
