HTR-5540 won't run in Digital Mode
Brad Johnson
I have a Sony DVD player hooked up to it through a Coax digital cable. It will not run in digital mode no matter what I've tried. Does anyone have an idea what to do?
Yes. I have similar problem with HTR-5540. I tried
APEX AD-1200 didn't work with Coax.
But with Optical I am able to get it..
Phil Krewer
Brad,
do you have the DVD input set to auto on the 5540, and do you have the DVD player set to digital out.
Phil
With HTR-5540 Coax works only in the CD mode.
So, Select CD.
Ps:
If your video stream goes through receiver, select DVD first
to get the picture then select CD to get sound through Coax. When I selected CD alone, it was
not displaying pictures.
To get DTS and other stuff, make sure your DVD player is not processing
any data, make it to spit bit stream/row data and let
the receiver do the processing.
hope this helps.
