Speaker Selector
Username: Primec
I want to power two 250 watt, 8 ohm loudspeakers with an amp in bridged mode. Amp is 250 watts/channel when bridged, minimum 8 ohms impedance. The user manual says you must use an impedance matching speaker selector or volume control when hooking up 2 loudspeakrs in bridged mode. What specs do I need a speaker selector for my configuration?
