Bronze Member Username: BlazerPost Number: 11 Registered: Feb-04 | Ahhh the age old question which evokes much debate on this forum and others. Thought everyone would like to see what Onkyo's website had to say about this. It surprised me a little. http://onkyousa.com/faqs_detail.cfm?detail=1&id=203 |
Silver Member Username: John_aPost Number: 303 Registered: Dec-03 | Oh, no, not again. Coaxial Digital Connection Vs Digital Fiber Optical Connection? "Technically, a coax connection will sound better because there is less processing to the signal." Onkyo is wrong. There is no processing. It is a stream of 1s and 0s. You could send the stream by carrier pigeon and it would still be unprocessed. If someone shot the pigeon, there would be signal degradation. That is different. |
Silver Member Username: Elitefan1Post Number: 265 Registered: Dec-03 | I prefer coax because coax cables are much more rugged and less prone to damage due to bending etc but sonically I fail to hear any difference at all. Just another myth IMO. |
New member Username: StonePost Number: 9 Registered: Dec-03 | No debate, why not hook up both and let your ears decide? |
Silver Member Username: Elitefan1Post Number: 266 Registered: Dec-03 | Stone, Good suggestion. Since I have never heard a difference what I always tell people who ask is to use whichever cable your receivers default is for whatever component you are hooking up. This way you avoid the hassle of changing the input settings on the set up menu, just plug and play.I do think it's nuts how much you can spend on these cables as the basic models do a great job. A person can really get carried away on interconnects and speaker wire if not careful. I personally like the basic models from Phoenix Gold. |
Bronze Member Username: AvmanKansas City, MO US Post Number: 26 Registered: Mar-04 | can some one tell me why if your just sending a bit stream, why do i hear a diffrents in cable. ive tryed cheap ones and then i bought a z series monster cable one and it help out alot, why in that |
New member Username: LarsaasTrondheimNorway Post Number: 4 Registered: Feb-04 | The placebo effect? Seriously, can't a coax cable pick up external electrical interference and feed that into the receiver? I'm not talking about disturbing the digital bits in the bitstream, but disturbing the electronic circuitry in the amplifier through other means. Just wondering - I really don't have a clue about this topic other than that the bits themselves should come through equally well on fiber and on coax cables. |
Silver Member Username: John_aPost Number: 314 Registered: Dec-03 | Lars, Yes. This is a reason I personally prefer optical. My guess is, it works the other way round, and the co-ax cable can generate radio frequency interference. But it should not be a practical problem if the connections are secure and the cable is shielded. |
