Best reciever to Replace AVR 20
Username: Zrgreg
Hi;
I have an HK AVR 20, which has given me many years of pleasure, but I am looking to upgrade mainly because I have installed the system in a larger room and the AVR doesn't give enough to the rear surround speakers (PSB). Options are Yamaha RXV557B or Marantz SR4500. Seems as though I am leaning on the RXV beacuse of features. Feedback is welcomed
Username: Edster922
Post Number: 508
what's your max budget?
Username: Eramsey
South carolina United States
Post Number: 129
Gregory, you may want to consider another HK or Marantz, Forget about the Yammie as they "fudge" their power specs with their budget model receivers. E.Ramsey
Username: Zrgreg
I would like to keet it under 500 however I can go a little higher.
how about the HK AVR235??
Username: Eramsey
Post Number: 135
Excellent choice, but better still I have the AVR 335. Available from JandR.com for $469 delivered. E.Ramsey
Username: Edster922
Post Number: 512
Gregory,
You might be able to get an HK 430/435 or higher model if you go to Harman Direct on eBay, these are refurbs but they come with the full original factory warranty.
