Help w/ product selection
Username: M26e4u
I am re-doing one of the extra bedrooms in my house and converting it to a massage room for my girlfriend. My plan is to some in-wall speakers. I already stripped the walls down to the studs and insulated them also ran the wire for the speakers. I am now ready for some product selection and need some help. I was going to use 4 in-wall speakers (preferably round and w/ paintable grills) and I needed a simple single cd player for mounting in a closet. Any suggestions would be helpful.
thanks
Username: Claudermilk
Post Number: 115
Since the only requirement specified was in-wall, I'll throw Paradigm out there; they have a number of in-wall speakers. I've never listened to any of them however.
I bought a 2nd Hand Wharfedale speakers model 505.2, rear speakers "Modus" and high range tweeters, I think it is Model 002284 (3 small speakers in one assembly). I would appreciate if someone could suggest A/V Receiver for these set of speakers. Do I need a subwoofer? Any recommendations.
Username: Thx_3417
Bournemouth, Dorset United Kingdom
Post Number: 204
I wondering how well these in-wall loudspeakers perform without the sub bass turned on, how low will they go and at what sound pressure level and frequency range too are they has good as installing three matching loudspeakers into a THX Baffle wall!
P.S. let me know as like to install in-wall for the ceiling Height surround as they will be flush!
Username: Timn8ter
Seattle, WA USA
Post Number: 192
Being in the UK I'm surprised you haven't checked into EJ Jordan. A pair of JX92S mounted in-wall would work well enough you might go without a sub.
http://www.ejjordan.co.uk/index.html
Username: Timn8ter
Seattle, WA USA
Post Number: 193
Here's an example. These people decided to put a grill over the driver but it's not necessary.
http://www.creativesound.ca/jordan.html
