Rotel RCD 1072 too bright?
Username: Wildmind
Hi folks,
Just bought the Rotel last month, played it continuosly for a week. Set up has Rotel RA 1062 connected with Van den hul Cs122, Mission M52 with Straightwire Quartet cable-small room.
Can't figure why bass and warmth is missing and the sound is waay too bright on most Cds? Would Dynaudio Audience 42 be a good match?
Thanks in advance.
Username: Wolfson
Post Number: 19
Why dont you try room treatments if possible. It makes the biggest difference over any other componet in the system. No matter what componet you buy if the room has a reeflective quality then the system will bounce the sound allover the place creating a brighter effect.
I find it amazing when I walk into places with several thousand dollars in gear and not a single room treatment is to be found. ALL rooms need some sort of treatment.
