Cambride Audio A1 - Two Speakers & One Sub?
Hey,
I Have a cambridge audio A1 amp, which currently has two speakers on it ( from the L & R terminals ). There are no more terminals, but i have a sub here which needs some use =). Is it possible for me to use this sub even though all the terminals are taken up? I heard i could connect the + of the sub to the + of the R channel, and the - of the sub to the - of the L channel... is this true? Will this amp be able to power two speakers and a sub? the subs 500w max...
Thanks in advance.
Ive looked on the back of the amp and i see it says 'Impedance 6-16 ohm'. On the back of the two speakers they say 8 ohm. can i work out from this if the amp can power a sub aswell?
Username: Cpgolf
hey
i need help finding and amp. Anyone got any ideas for a my subs. I have 2 kicker Comp c154 15". if you got any ideas please email me at cpballr11@aol.com
or just post it for me so i can read it
