Copied DVD
Username: Frstnight
Can you tell is someone has borrowed one of your DVD's and copied it?
Username: Sem
New York USA
Post Number: 466
Only if they've returned the wrong one :-)
Username: Sudden
New Delhi, Delhi India
I wanted to get two things sorted out ??
(a) Which is the best players/make to purchase that can play all possible media (DVD's disc) and all possible formats under the sun. That is one aggressive monster that can run anything you put to play.
(b) Which is the best method/ software to copy DVD-9 to DVD-5. How to get acheive maximum without loss of quality.
Username: Frstnight
Sem, so there is no way to check the DVD and see?
Username: Sem
New York USA
Post Number: 467
None that I'm aware of.
Anon101517
DVD Shrink - No loss of audio quality, video compression is hardly ever even noticable especially if all the special features and menus aren't included
