Bronze Member Username: Turkish621Post Number: 31 Registered: Dec-04 | Ok, so this will show my A/V ignorance but anyway. What are pre-outs and what do they do? When would you use them? |
Silver Member Username: Touche6784Post Number: 370 Registered: Nov-04 | pre outs are used when you are going to be using dedicated amps. i believe this bypasses the reciever's speaker connectors. if you have an amp that you want to use with the system, you hook up the amp to the pre outs. |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 3724 Registered: May-04 | Read and bookmark these links: http://lp2cd.com/audio_terms/a/index.html http://sound.westhost.com/site-map.htm https://www.ecoustics.com/electronics/forum/home-audio/56618.html |
