Running 2 subs????
Username: Darrenmc
Winnipeg, Manitoba Canada
I just recently purchased some Angstrom Modular 2, 4 & 8 speakers. The 8's are LFT's or Low Frequency Transducers. They are in a sense the subwoofer of the system and the 4's sit on top. Here is the link if you're not sure what I mean http://www.angstromloudspeakers.com/prod_modular3.html. Now the dealer I go to totally forgot that I already have a Jamo SW410E subwoofer. So I have the Jamo sub hooked up to the sub out on the receiver(Onkyo TX-SR701) and the Angstrom 8's hooked up to the pre outs on the receiver. Is this overkill, do I now not need the Jamo sub? If not, I was thinking of trading it in and maybe getting a power amp to drive the Angstrom 4's seperately. If I'm right and it's overkill can anyone recommend a decent power amp for under $750US? Help me if you can. Thanks
