Anyone ever tried the old center channel trick?
Username: Kegger
Warren, MICHIGAN
Post Number: 2443
what I mean is the use of the positve speaker output from the left channel
output from a 2 channel stereo amp "ST70 in my case" and the negative on
the right channel output while at the same time using a stereo pair of your
speakers just like normal with a third hooked up this way.
It's been written about for helping car audio getting better imaging or for
very wide rooms to help center the voice. "I believe it's where dolby surround
got it's start" It's an old trick that's been around for awhile.
IF YOUR RUNNING AN AMP WHERE YOU MAY BE WORRIED ABOUT DROPPING
THE SPERAKER IMPEADENCE TO LOW I WOULD NOT SUGGEST TRYING THIS.
Well I came to a conclusion for a new use for this trick that was broght up
by my current work area system. The system uses a pair of bookshelves that
could use some extra bass and I have plenty of drivers and cabinets not to
mention a plethera of xover parts. So I put a 10" bass driver in a pretty big
cabinet used an old passive sub filter "coil and cap" hooked it up the way I
described above shoved it under the desk and whala I have great bass now!
Pretty cool setup, I was preparred to use a pot on the bass driver and rework
the passive network if need be, but I'll be darned if it's not just right ,HUMM!
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 487
It's been a while Kegger!
It thought there was one method which uses an actual network where you can dial in the volume of the center channel. Paul Klipsch did that with Klipschorns in far away corners and a center speaker (long before multi-channel receivers).
