Bronze Member Username: W00bPost Number: 86 Registered: Mar-05 | So i was looking at the specs of this speaker: http://www.axiomaudio.com/m80ti_main.html it operates at 4ohms.. now here is the kicker. i have a very old amp (1984) AKAI AM-A70 receiver. i can't find anywhere online, and god forbid if i have the manual somewhere.. but i have no idea how to check if i can run 4ohm speakers off of this receiver. if any of you can help, please help! |
Bronze Member Username: W00bPost Number: 88 Registered: Mar-05 | no input from anyone? hmm.. |
New member Username: Audio101Battle Creek, MI USA Post Number: 1 Registered: May-05 | The receiver most probably has an 8 ohm output, base soley on its age. You might find a manual at any of the following sources: http://www.vintageaudiomanuals.com http://www.treasurechestcorp.com http://www.servicemanuals.net I hope this helps. John Loser Audio101 Consultants Battle Creek, MI |
Bronze Member Username: W00bPost Number: 91 Registered: Mar-05 | ok, question for you then, what if i were to drive this 4-ohm speaker with a car amplifier? they default to 4ohms right? |
New member Username: Audio101Battle Creek, MI USA Post Number: 3 Registered: May-05 | Dustin asked: "ok, question for you then, what if i were to drive this 4-ohm speaker with a car amplifier? they default to 4ohms right?" You need to look at the specifications of the amplifier you want to use. Many are rated for a 4 ohm load and many are rated for a 2 ohm load. In either case, you could safely connect the 4 ohm speaker. |
Bronze Member Username: W00bPost Number: 92 Registered: Mar-05 | awesome, thanks alot john! |
