Help me buy some good floor speakers
skumar234
I am looking to buy good floor speakers in the range of 700-800 dollars/pair. please suggest . your help is really appreciated
thanks
Username: Paul_ohstbucks
Post Number: 731
It depends on what you're looking for.
You might try being more specific.
Username: Artk
Albany, Oregon USA
Post Number: 349
Lots of great speakers in your price range. As Paul said we need more specifics. What are you using them for? What will you drive them with? Need more info.
skumar2341
mostly listening to music to start with. i am novice. i might later add rear speakers, center channel and sub to make it complete home theater.
i was thinking of yamaha rx 2500. i checked out the energy c-9 at good guys . they werent too bad and they are at 1/2 price.
i am sure you guys will know more. do let me know.
thanks
skumar2323
the music that i listen to - rock, classical, jazz being the main . i also listen to all other kinds of music.
Username: Max190
Maryland Heights, Missouri US
Post Number: 32
I am using these as fronts in my HT.
MSRP=$750
Nice detail without being bright or forward sounding. Outstanding bass.
http://www.phasetech.com/cgi-bin/index.cgi?item=12
Username: Joe_c
Oakwood, Ga
Post Number: 217
I have heard these and they sound great to me, hopefully axiom will be next for mehttp://www.axiomaudio.com/m50ti_main.html
Username: Skumar123
which one is better psb image 65t or the axiom m60 ti. I havent heard either but just wanted your opinion.
m60's are 900/pair psb are 1099/pair MSRP
bumblebee
mordaunt short 914s
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 446
Klipsch Cornwall's (on ebay or audiogon)
NADMAN
I've got PSB Image t55's. Can't recommend them highly enough. They are also very efficient...combined with my NAD C320BEE, I am on the verge of being evicted...
Username: Skumar123
i m just curious to ask how are the martin logan clarity they cost 2600$ pair. they sound good Also vienna acoustics. i heard them in mangolia audio video store.
i never see anyone talk about them in a good or bad way...just wonder why?
