I am wondering which speakers to buy for front floorstanding. I am sticking with JBL Northridge E series to match the rest of my components. My receiver is the Denon 3805. I have JBL EC25 as Center, JBL E10's as surrounds, and JBL E250P as the sub. I was wondering what I should buy for fronts. I was looking at the E60's, E80's, E90's, or E100's. Cost doesn't matter as one could save money for the higher priced speakers. I just want to get the best sound for movies. Any advice or help would be great.
If cost doesn't matter and you want to stick with the JBL Northridge series then the E90s or E100s would be the most logical choices. With the Denon you should have sufficient power for any of them.
Isn't there a place near you where you can audition them?
Do you plan on sticking with JBL? There are lots of better options at the same price level. JBL is your typical mass market speaker with run of the mill components. You can do better for the same amount of money.
