Acoustic energy evo one
well, are this go well with nad c320bee&c352? or have you another suggestion for that budget. I mostley listen rock, chill out, some jazz, reggea. is it true that I can't get much bass from ae? and is it difficult to run?
thanks
Username: Frank_abela
Berkshire UK
Post Number: 483
Anon
the AE will suit that combination fine. It doesn't have big bass but it has good bass. It rocks well and is an involving listen. Place it on a decent stand and it will work fine.
Oher competitors for similar money would be the B&W DM303, also very good - and the B&W DM600 which is great fun.
Regards,
Frank.
