Yamaha amp burning smell
yamaha AX700u has power, but have a burning smell, no sound from anything. Smell is coming from box inside with copper around it(xc281). Is it fried or can it be fixed, a rough idea on parts, price, ease, or if it's worth it.
Thanks for any help!!
Username: Pimpzeus
United States
well im sorry to say but u melted it down. u cant really fix it.. how did u hook it up excactly? message me man
Username: Thx_3417
Bournemouth, Dorset United Kingdom
Post Number: 213
Oh BUGGER ME!
Its toast must have had loose wire that could have possibly crossed over with the output stages.
Hope you get your home cinema back up and running soon, and always remember to read the manual before undertaking the task of setting up the home cinema, no mater what even if you're a professional sound engineer, as some of them around today are total DONKYS COWBOYS and like the...
...ABC cinema and the ODEON at Westover Road Bournemouth the sound is to the point of breaking down...
ABC and ODEON who have been named and shamed DONKYS you are.
DONKEYS MAN!
