Zone 2 Question - Denon 2805
Bill J.
Perhaps a basic question that I'm just missing in all the documentation, but does using the zone 2 audio outputs reduce the main room to 5.1 or can the receiver pump out 7.1 to the main room and sound to zone 2?
Are most receivers in this price range the same in this behavior? Thanks for the help!
Username: Paul_ohstbucks
Post Number: 638
yes.........you can watch a 7.1 movie using your HT, and listen to a different source in zone2.
Some have limitations and require only basic 2-channel stereo in zone two. It depends.......
I cant speak for all models.
Good luck
Username: Phantom2
As long as you use the audio outs with another amp you're fine. If you use the speaker jacks you drop to 5.1
