Reciever picks up Radio Station
johngerry
Does anyone know if this is a problem with the reciever or the house wiring? The ground and common are connected at the breaker box.
thanks
john gerry
thearthurclone
do you only hear the radio when the receiver is set to an input, but no source is present (like set to dvd...but the dvd player is turned off).
quite a few receivers have this type of radio bleed through...but it's definitely a problem if you get the bleed through when a source is present.
johnpetergerry
I hear it both with the source on or off, plugged in or not.
