Tympani Acoustics sub
I found a Tympani Acoustics TPS-15 digitally powered sub-woofer and I would like the specs on it. The speaker itself is fine. Something on the circuit board is broken and wondering if I should bother fixing it or throw it out. I tryed to find information about the company and the sub but had no luck. If you could send me any info on it I would appreciate it. My email is psy8@webtv.net
The amp regularly fails. If you would like to contact the manufacturer they are:
Amtec Manufacturing Inc.
6095 Ordan Drive
Mississauga
Ontario, Canada L5T 2M7
Phone: 905 564-9471 Fax: 905 964--245
