Bronze Member Username: ShadylimitedxPgh, Pa Usa Post Number: 25 Registered: Apr-05 | what do u ppl think of these splw10s my friends whats 2 (no) (good) (bad) (ok) http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=3291%26item%3D5768014216% 26 |
Silver Member Username: DmwileyPost Number: 446 Registered: Feb-05 | Wouldn't purchase off ebay without first hearing the product. |
Bronze Member Username: ShadylimitedxPgh, Pa Usa Post Number: 26 Registered: Apr-05 | i was goin 2 get dem sum 1 else but i wanna no how they sound first |
Silver Member Username: PetergalbraithRimouski, Quebec Canada Post Number: 386 Registered: Feb-04 | Scott wrote: i was goin 2 get dem sum 1 else but i wanna no how they sound first I have to work to parse that. Please write correctly; you're not chatting here. |
Bronze Member Username: ShadylimitedxPgh, Pa Usa Post Number: 27 Registered: Apr-05 | i was goin to get them somewhere else but wanna know if they sound good |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2233 Registered: Dec-04 | i highly doubt they will have good sq |
Bronze Member Username: ShadylimitedxPgh, Pa Usa Post Number: 28 Registered: Apr-05 | how bout spl |
Gold Member Username: SubfanaticWalton, Ky Post Number: 2332 Registered: Dec-04 | you should get a single 15 inch avalanch, 299 bucks, and that should beat out both of those |
Bronze Member Username: ShadylimitedxPgh, Pa Usa Post Number: 29 Registered: Apr-05 | need 10s lol already made the box an it cant fit no more than 10s |
