AMP OVER HEATED
Username: Anthonyiosos
I came home from work and decided to listen to some music, I turned up the amp and my speakers were giving sound but with poping noise.
I had my amp on for 2 days because reading somewhere said this was ok, keeps your amp warm. Doesnt stand by do this? And do you think it was the amp, I never have speakers cranked up.
kabah
my amp keeps over heating and just shuting off the subwoofers is there a way to fix this?
kabah
My amp keeps overheating in like 10 minutes for some weird reason is there a way to fix this?
Do you keep your amp in a cabinet? Sometimes you can open the top keeps it coolor. If you have no kids tat will touch it.
Username: Jeffo
check your speakers, see if they match mate.
Username: Audioholic
Sounds like your overheating your amp. Try adding a cooling fan. If you can't do that, check the impedence of the speakers and that of the amp and make sure they are compatible. Here in Minnesota, overheating is not a problem except in summertime.
Username: Carisloud
Burn, Minnesota Usa
its all the wiring of the sub. wire subs at highest ohm see if problem cont...
