Ok. So I decided to try and be smart, and change out my popup light myself. Easy enough, I had it working, but then I got stupid and decided to see what would happen if i put the two wires that connect to the light together with the power on. Well I burnt out the light, no biggy, however, now my turntable won't even power on. Anyone ever had or heard of a similar problem to this case? I'm really not sure what happened. I'm no electrician but I really don't see why this could have messed the entier table out. Also, this might be of use, but I noticed that I don't have a fuse installed on the power circuit? Hopefully that's not what caused this.. :/
