JVC Receiver ; Will Not Power On?
Username: Bbalnyc
Hi everybody, I recently unhooked my JVC, RX-805V stero receiver, and relocated it across the hall. Before i did this it was working fine, it had six speakers and a am loop connected to it. I hooked it back up in another room and only two lights came on, the surround sound light and power standby light. I don't think it has to do with the am loop for I connect it back up and it does not work. The speakers are fine, and from what I see, it is getting power. One of my other receivers had a similar problem, I fixed it by finding a switch on the bottom, the JVC does not have that. Well, thats my problem I would be very thankful if someone would come through.
Username: G1anfranco
Have you tried moving it back to it's original location?
