I tried them, they are excellent. The only one concern I have is poor bass. Can you recommend anything similar but with better bass? I would appreciate your advice.
the MartinLogan Mosaic will give you all around better sound. Having a planar midrange as well as tweeter, these will sing like you won't believe, ESECIALLY if you like the highs on the montage, which only has a planar tweeter.
The other difference is that the mosaic has an 8 inch woofer, bigger than the twin drivers on the montage. Even though the twins may seem like a better idea, the mosaic has a higher excursion, letting it play deeper and louder.
You will get a MUCH better speaker for only $500 more than the montage
I have heard the Mosaic, and when broken in, it is a mellow, seductive speaker that sucks you in in ways that will be very noticible, ESPECIALLY in imaging.
I have the Mosaics for sale for 1400$ .. Chicago area only ... will deliver or available to pick up. I bought them a week ago, brand new. See them at Tweeter for $1995.
