Seperate Processor to replace AudioSource?
Username: Okiecaver
It's time to replace my aging AudioSource surround processor. I really like my JVC integrated amp- Pioneer power amp set up, so I'd like just the processor, if such a beast is available.
Any suggestions out there?
Thanks!
Username: Gman
Post Number: 245
Most quality separate surround processors are expensive, because most people that buy separates new are paying medium big to very big dollars.
Since it sounds like you don't want to spend much money, I would look at audiogon.com in the classified surround processor section and see what is available. You may find a more recent AudioSource or other brand you like. You can also try ebay.
Username: Okiecaver
Thanks!
I went to Audiogon and found 3 items I'm interested in, sent notes to all three and just waiting for replies!
Thanks again,
Brock
Username: Gman
Post Number: 248
Good luck. I hope you are succesful in obtaing what you want.
Buying quality used equipment is a great way to get wonderful performance at a reasonable price.
I would recommend the Sony SDP-E800. It has 3 optical
inputs one analog, features Dolby Digital and other
configs and it was about $300 NEW 3+ years ago.
try ebay
