PSB Image speakers
Username: Jiggad369
Post Number: 14
hi i jus bought psb image 4t's and i was wondering if i should biwire them or just regular wiring. and can anyone trully explain to me what exactly is bi-wiring? thanx.
Username: Cornelius
Post Number: 115
I had 4t's and bi-wiring made no difference in sound. It's sending speaker cable seperately to the tweeter and woofer. The only time I noticed a difference was in bi-amping, but I ended up getting even better results with a better quality amplifier. I always think simple (less wires) is better.
Username: Jiggad369
Post Number: 15
so should i run a pair of wires from the receiver to the sub then from sub to the 4t or run the wires from receievr to the 4t straight and use a separate subwoofer cable?
Username: Jiggad369
Post Number: 16
i'm getting a Marantz SR8400 so i have enough power.
Username: Cornelius
Post Number: 116
run 'em seperate - one run to the 4t's, another to the sub.
Username: Jiggad369
Post Number: 18
so regular 10-14 awg speaker wire to speakers and run a analog cable to subwoofer right?
