Harman Kardon AVR 100 Fuse Blows
Username: Hawk1192
The 125/v 5/amp Fuse blows as soon as I power up the receiver I have replaced the fuse and it blows again.
Does anyone have an idea what might be causing the fuse to blow.
Visually I dont see any thing that looks burnt on the board but what ever is causing the problem im thinking might be next to the power supply.
Can anyone help?
Username: Only_mike
Seattle, Wa Usa
First disconnect e-v-e-r-y-t-h-i-n-g from the reciver and unplug it from the wall. Hold it upside down and shake it a little in case one of your kids dropped a penny or paper clip inside.
mz
Pete Newman
Does anyone know of a way to extend the Soundsticks II controller speaker wire? I bought an SVHS cable, but apparently the system detects the extra impedence as a signal to lower (or mute?) the sound.
If I were to put a second cable on the other speaker would the system then "feel' balanced?
