HOW TO USE AN OLD AT POWER SUPPLY TO POWER A CAR AMP
G.Z.
Does anyone know how to use an old AT computer power supply to power a single channel sub car amp
Username: Only_mike
Seattle, Wa Usa
The 4 wire connector that goes to the hard drives has two black wires and a yellow and a red wire. Use the yellow (+12) and either of the blacks (negative or ground). Here's a link for the diagram. http://www.hitachigst.com/hdd/support/cabling/serial.htm
mz
G.Z.
thx
I used that trick to mount a 200watt amp and 12inch sub to the back of my computer chair. I plugged in a 5.1 system and used the amp and sub for the ".1". In Need for Speed 2 Underground my chair rumbles as if I were actually in the car. When the bad guys in any given FPS shoot me, i get jolted. I can feel the kickbacks from the guns. Very highly recommended hack for you gamers.
Thanks, Mike Z. for that info
