New member Username: Duke46New bern, NC United States Post Number: 1 Registered: Apr-05 | Does any one have a user manual for the P-L51 turntable or even a latter model? It would be nice to know what every thing does and how to use it and maube why it does change its self from time to time? |
Unregistered guest | Have the user manual for the P-L51 turntable. Took turntable out of storage shed yesterday and can't get tone arm to move. Can photocopy and mail you a copy as it is 16 pages long because only one column per page is in English. |
New member Username: Duke46New bern, NC United States Post Number: 3 Registered: Apr-05 | Thanks for the offer but I just got one in. Soulds like the little belt went bad while in storage? I had to order one for mine and Sansui made it easy to get to with the lid that removes under the arm and after you remove the table. I got mine from this site. http://www.vintage-electronics.cc/turntablebeltsg.html Good luck and thanks for the reply. Duke |
Unregistered guest | Jan. 9, 2006 Looking for Stylus No. and Service Manual for Sansui P-L51 Linear Tracking turntable. Can live without manual but need stylus. Thanks |
New member Username: FivecheersPost Number: 1 Registered: Mar-06 | I HAVE AN OLD SANUI p-L51 TOCK IT OUT OF STOREAGE I CANT FIND ANY PAPER WORK ON I WOULD LOVE TO GET IT WORKING AGAIN. THE UNITE IS IN GREAT SHAPE IT JUST WOUNT SPIN CAN ANYOME HELP THANK YOU , SAL |
Gold Member Username: Jan_b_vigneDallas, TX Post Number: 7947 Registered: May-04 | You'll need to remove the platter and find the reason the platter won't spin. Is it the motor, belt or something else? |
New member Username: Pen2001Post Number: 1 Registered: Feb-07 | I took my old PL51 out of storage and i cant get my stylus to move and it just says that its locked and if anyone has a manual please send. |
New member Username: Dmite357Temple Terrace , Fl Post Number: 1 Registered: May-07 | Does anyone know how to unlock the PL51turntable? Just got mine out of storage removed the screw but it still shows as being locked. Help please. |
