RYZ NEEDZ HELP Unregistered guest | i screwed up and deleted the hidden folder to make my lyra pdp2840 work.. HELP!! someone give me a site to get the folder back pleeeeeeaaaaaaaassssssssseeeeeeeee |
hopethishelps Unregistered guest | Try EI700625%2C00.html#upgrades,http://www.rca.com/content/viewdetail/1,,EI700625,00 .html#upgrades. This site has the firmware. It may or may not work. I formatted mine and now it won't work. I called tech support and they aren't too technical at all so if it doesn't work I dunno what to say. If you find something that work's drop a line cause I got the same problem. |
