Pioneer DV - 578a "countdown" issue
Username: Yesongs
My 578a can not seem to play SACD's that have a "count down" before a track begins.
It basically just skips any "negative" section, and jumps right to the next track.
I called tech support, and they indicated that it is a bit of a design flaw, and said there was not a fix.
Is this correct, and have any of you had similar issues?
Is there anything that can be done?
There is one CD that I have, (Nektar's Live in NY) that has a track that is about 20 seconds long and "counts down" - the player just skips it
Any help would be appreciated,
Eddie
