I need help! I've hooked up a Sony CD/DVD DVP-NC685V to a Yamaha RX V1000 receiver. Everything sounds fine with the exception of DTS. I hooked up a Monster optic cable to the correct ports of each unit. If I select an Analog input, I can heard sound. If I select DTS, the led for DTS lights up but I hear nothing. The DVD player is displaying "DTS". Any suggestions?
good question. Check your Receiver, when it is in DVD mode, does it say that it detects the optical input? On my receiver I had to change the input from the default (analog) to optical for the DTS to work.
I don't have experience with Yamaha receivers though, so try that and wait for someone to post who has more expeience with your products.
rentersl
you need to set the dvd player to enable DTS from the DVD set-up menu
I agree with "rentersl". You've probably not set your DVD to output bitstream/DTS. When it is analog mode your Receiver is getting a 2 channel feed from your RCA cables (and probably processing it into 5.1 artificially). I'd suggest pulling the RCA cables leaving just your optical cable for audio connected. Then go into your player menu and adjust your audio settings until you hear sound.
