Older cd player problem
Username: Terminator92288
I have a clarion drx4575 cd player, its an older player but in good shape. i recently put it in my neon and got it working fine. recently everytime i play a cd it gets to the 3rd or 4th track and starts skipping and getting staticy and then cuts out with the cd player saying theres an error and wont read the cd. any suggestions? thanks
Username: Dmwiley
Post Number: 334
Toss it. Cost of repair would likely exceed cost of replacement. Could try cleaner disc.
ben hall
pfft dont listen to the above its just needs realigning thats all not much to fix or if you look it up it may tell you how to do this
