Question about impedance setting
Username: Ximen
Post Number: 11
My receiver has a impedance switch which has two option: 4-6ohm or 8ohm. The problem is that my system have different brand of speakers with different impedance. My main speakers are at 5ohm and others are at 8ohm. Whic impdedance I should set for the receiver? Does it have any effect on the sound? Thanks
Username: Paul_ohstbucks
Post Number: 459
You'll probably want to match your fronts with the correct impedence. They're the big workhorses and you'll want them sounding their best. You're surrounds will still sound just fine after you set your impedence at a lower level.
Username: Ximen
Post Number: 12
Will this damage other speakers? If I set receiver to 8ohm, what will happen to the main speakers?
Username: Voriand
Post Number: 7
Yes and no
Impedience switch is probably nothing more than a voltage regulator to protect the amp and reduce clipping on high current speakers.
At resonable volumes the speaker will have no problem as long as the signal is clean.
The receiver on the other hand may go into protect mode if it has one or just burn up if played for long periods at high volume.
Set the switch to 4-6 ohm or get a better quality amp.
Post Number: 462
tao,
Setting the receiver to 8ohm wont hurt your front speakers. If anything, it's possible they wont sound as good. You can try both and experiment.
Username: Eramsey
South carolina United States
Post Number: 40
Paul is right set the receiver for the 8Ohm setting. If you set it to the 4-6 ohm setting the power supply in the receiver will limit it's output and may reduce your available volume before clipping by as much as 50%! If however you do this and the receiver clips or goes into protection mode with a moderately not exteme volume very often then it's time to reevaluate the situation and purchase a more powerful receiver or buy an easier to drive speaker set. The continued use under the above condition will result in damage to the receivers amp and/or damage to the speakers. E.Ramsey AAS industrial electronics
Username: Max190
Maryland Heights, Missouri US
Leave your receiver at 8 ohms and read this.
http://www.audioholics.com/techtips/buyingguides/avhardware/receivers.php#impeda nce_selector
